Genuine Injector?
Does it offer the same improvement as a new set of injectors??
When properly cleaned and spray pattern checked they also change the filter. So yes, good as new. There are afew injection cleaning businesses around. Have all 4 checked and if one is non repairable then you buy a new one from GSF or ECP. Usually the oe injectors will be Bosch so easily available. They should be cheaper than £37 as well.
Where else could you get a set of new injectors from? One of mine is gone but im gonna change all 4 as its hitting the 100k mark also now and saves me doing it again hopfully :P ive got new HT leads as well and its had an oil/plug service :)
