sure they're the right bolt spacing?
I've never struggled and I'm a mechanical r****d. Try undoing the ball joint first?
lift the bottom of the suspension arm up and slot thehub bit into it, if you get the bottom bolt in first the top one is a piece of p*ss lol
but the top one makes it a b**ch to put the bottom one in if you try putting that in first if that makes sense....
basically wiggle it about until you get the bottom one through, then do the top bolt
Wrong. That'd make it further away.
Use a ratchet strap/rope or something similar that can be removed when the bolts are in. Put it round the wishbone in a loop and stand or kneel on it to pull the hub down.
Make sure the cars jacked up both sides too as you will just fight a loosing battle against the ARB.
Make sure both sides are jacked up first that'll make it a lot easier.
Then just give it a few good pushes down and have a bolt ready to go in.
John...you've not seen the size of me!Why has no one mentioned a dose of mtfu yet?!
If its still a struggle a lever bar (or say a trolley jack handle) over the arb and under the wishbone will allow you to lever the hub down a little bit.
Have you only jacked one side up?
If you have you'll never do it because the ARB will be pushing that arm up to match the compressed other side
Get 2 axel stands and get both sides in the air
Piece of piss then
Lol, on a sidenote can I have 2 tickets please?
To the gunshow.
Cheers guys...will need 2nd pair of hands I think to cover it...as can't pull hub down AND manipulate the holes for the bolts to go in...
Ermmm what does the model have to do with whether you use spring compressors or not?
If you have the springs compressed you can push the bottom of the strut up to line the holes up as it's not under tension.
I've always fitted struts back onto cars with the springs compressed and then remove the compressors on the car, makes life a lot easier, unless you're fitting coilovers then I just have them wound all the way out so the springs are loose
Theres just no need for compressors on a 1*2 at all. Just adds work and hassle to the job.
Glad you got it sorted mate
Should have gave me a call Don would have come and sorted it for you in a few seconds
glad you sorted it mate.
Flol at some of the early suggestions in this thread...
