Going from Magnex to standard....
Anyone ever done this?? I just want to know how much it would cost to get the standard zorst put back on, just the backbox? If so I will be selling my magnex oval backbox.
  1996 Valver
I have just changed the powerflow system on my Valver back to standard, And I can't tell you how much better it is..........paid £130 for standard cat bk, a cup shouldn't be that muck more I don't think..........£150???
or £80ish for just b-box
  Clio 172 mk2
If it's a Mk2 172/182 it'll be expensive as the exhaust is in one piece from the cat back.
I was quoted around 300 notes from a Renault dealer!!!!!
Gaz_
  Extreme mode
yep i''ve done this, i brought a magnex as the centre section on my stock exhaust broke with some enthusiastic driving :eek: .... liked the way it sounded but wasn't too taken with the looks..... then the magnex centre section developed a rattle, sold it and got a new reno centre section (up to the rear axel) iir around 200 notes, my back box was ok, and i fitted it for nowt.....
imo the magnex does nothing for performance unless your doing big mods, i think the standard one is fine performance wise, just abit poorly made
  Nimbus Clio 197
so is it all one section from cat back? or can u just pop on an aftermarket backbox?
Mine is just the backbox, he did seem to butcher the standard backbox off like but he said they could just make a sleeve to connect the standard back to standard again. I still have the standard backbox in my garage.
The exhaust sounds lovely, not too loud when your pottering around but it really comes to life if you floor it.
I need to go back to standard as I'm going to use my car for my business and i dont think it would make a good impression turning up with the magnex on.
Gaz_
  Extreme mode
new its all one system from the cat, but if one part of the section fails the system is cut round the rear axel area. You can then either buy a seperate centre section, or backbox, depending whats failed
Gaz_
  Extreme mode
reno do a sleeve for around 18 quid (actually quite good)!
i used this to join them back up.
  RS Clio 200
I did exactly that - removed a Magnex Oval and fitted the standard. It was just too loud and at 60 there was an annoying vibration from the back.
It cost me just over 300 for a full system (cat back) from Renault. I sold the Magnex and a set of springs (on here!) to get back some of the cost.
The original is more "refined" but still makes a nice noise when it revs though.
