M90SR
Cars not starting now and its the first time I have started it since removing the boot lid (been sent to a body shop for some work)
I don't know for sure if its the boot and the likely answer is to just try connecting the boot again and I will when I get it back.
Just interested to know if anyone has experienced with removing a door (incl boot) from a car and it refusing to start.
The immobilizer might be the issue but the key symbol on the cluster does not come up. Neither does any other light.
I tested the HT leads and spark plugs. I also checked and refilled the fuel as the car has been standing for a couple months now. (I start it occasionally). All was fine.
I plugged the machine in and got the following relevant fault codes:
- 17978 Engine start blocked by immobilizer P1570
- 01330 Central Control Module for central convenience (J393) - sporadic - adaptation limit exceeded
I am having doubts though about the immobilizer because the car should start for like 2 seconds then switch off, but it doesn't. All it does is turn over (just the starter) and nothing else.
