Wouldn't worry about wiring unless your using 32gauge and your putting 100watts into them . If they're running of a headunit, not amped. Then your taking no difference from thin stuff to 8guage....
What the hell has wattage got to do with speaker cable???
Better speaker cable will give a better sound.
Size of the cable isnt always important either but the white crap u get with the speakers is very poor and is DEFINATELY worth replacing with something better.
Wattage is proportional to current drawn through it for a given ohmage.
A decent HU wil push out about 18w rms. Into a 4 ohm load will give 2.12 amps. At 8.5 volts. I very much doubt this rms figure is met, yet the standard white cabling you're on about will more than suffice the load of that 2.12 amps.
and thats how wattage is comparable to speaker cable. Better of removing the 6 x 9's all together TBH if you want better sound, unless you understand sound staging fully, and have a brilliant front end, in which case, you woudln't be asking questions about speaker cables!
I've since read the amp bit.... what amplfiier is it??? Do you have any RMS figures?
The rms of the amp has sod all to do with speaker cable size!!!
Ok.
Definiton. - For times when one cannot be bothered to argue.
