Got a blow from my manifold!!
  PH2 172
Just noticted a slight blow coming from my manifold aint sure if its where the join is or if its cracked how hard is it to fit a new manifold as i was thinking of just buying a new one but looks pretty hard to get to. And also if i put a new manifold and decat on with an aftermarket exhaust will the car be over the top to loud cheers.
  ValverInBits
172 4>1 manifolds are fairly cheap. the 182 manifold is 4>2>1 and better so go for around £200/£250. A 172 one is easily had for about £80 maybe £65
All exhausts make a different amount of noise. Go for a Ktec stealth
and buy a silenced decat
A 182 manifold is not a bolt on job. It requires a custom cat/ decat section
  PH2 172
I was thinking about buying a sport manifold and sports cat been told if i decat it it will bring the warning light on the dash board and ill have to keep changing it back when i take my car to mots the aftermarket exhaust im guna get is a from prospeed a custom made exhaust.
  lift number 1 @ btm
hi there,
i just saw your thread about the manifold. if it's any use to you, i have a 172 mani sat in the garage you could have for £25?
i'm close to chippenham so probably not too far away.
cheers. doug
  PH2 172
Well i aint sure if it is cracked yet but im guna get it looked at son ill get back to u though ok mate cheers for that.
  ValverInBits
yes - decats fail MOT and the light will come on
No - there are no "performance" or "sport" manifolds available for your engine only the 182 manifold.
DrR
  VW Golf GTD
Some people prefer the 172 manifold to the 182 one to.
  PH2 172
I know but that fits the 172 thats wat it says at ktec aint sure if im guna change the manifold might just put a performance cat and ktec stealth cat back on my car hopefully manifold aint cracked and its just a blow on the join
  BMW M135i
The 172 manifold isn't bad either tbh! Just depends on your preference of the charatersictics of a 4-1 or 4-2-1.
