grease on my wheal, i need help
Car  polo, here for lols
right i have just got back from holiday and found that there is a layer of thick grease on my front left wheal. i took the wheal of to investigate and have found that it seems to be coming from what i think is the joint on the suspension arm (im not very good with car parts). obviously this is a problem, but how bigger problem??
the only reason i ask is because i need to drive 120 miles to Leicester tomorrow. after this drive i can get it fixed there. im in two minds as to do the drive or not, but it is important that i get to Leicester tomorrow. what should i do!!??
I put a jubilee clip around mine as the metal band you can see in that picture broke, but it depends how much grease has come out, i caught mine early.
It's a pretty common problem , the clips are weak and they snap . I put some 10mm cable ties over my clips as soon as i bought my car as a preventative measure ;)
Repack with grease and jubliee clip like DrRollo says .
