Guess the problem
Car  Oyster Card
I thought I'd ask you lot as your far more qualified than the work experience boy who "fixed" my car today.
Heres the symtoms
1. Groaning/humming noise when I turn the wheel to the left above say 20mph
Does it only when I turn the wheel left, stops when I go 100% straight or right.
2. Clicking sound coming from wheel, every rotation. Like for example if you had a nail sticking out of it or a piece of chewing gum you'd hear it make contact with the surface every rotation, well I get a sort of click but theres nothing in my tyre.
This does it when I'm going straight or left but stops if I turn the wheel right.
Also how hard is the fan belt to tighten up it's screaching badly now.
It will be the wheel bearing for Q1:
Q2 will be something hitting the wheel, have a look to see if it’s the low warning wire on the brake pads,
Alt belt should easy enough, normally just a big spanner about 17mm, undo that a bit, add pressure to alt and tighten up!
