Hand brake light wont go off!
either a dodgy switch in the handbrake handle, or low fluid level (im assuming it has a float level sensor in the fluid resevoir) due to either worn discs/pads or poss just needs fluid topping up
if your pads/discs have worn then like i say that can cause the level to drop, or possibly a faulty switch or leaking brake hose or caliper, just trying to suggest the obvious and easy stuff 1st
itll be braik fluid level i had this, if it keeps happening then its a leaky cylinder seal in one of urs drums or a split hose
Al
