hard clutch in valver
They're very stiff standard.
If it's stupidly stiff, you're probably gunna need to get it changed.
When it starts snapping cables, it's about time.. Heh.
i had 2 new cables and the garage said the clutch was ok it was that the cable was not threded properly
mine was ** STUPIDLY ** stiff. got quoted £300 for a new one incl. fitting. so i decided to try a new clutch cable. solved the problem. OH and make sure u have a heat shield .. or it melts the cable.. i just had to fit a heat shield. and replace the cable again :)
ad
