Hard Drive Partition'd with XP wont work With MAC
  • Thread starter Thread starter Brown.
  • Start date Start date
B
Brown.
Well it works, i can access and download data files, pics n stuff, but i cant alter anything on the HD or Add files......any ideas Mac Boys ??
I've heard a £220 HDMI lead will fix that ;)
Something to do with little green men and ray guns causing interference.
Right downloaded it and installed.... cant find the program any were :(
We must remember that i havent got a clue what to do here....wtf is gui ?
something you see!
macfuse is driver which provides os x with extra filing systems. it's clever because it's basically a set of plugins that run at application level, which makes them a doddle to write and debug.
Once you've installed macfuse, it knows how to mount new filing systems. However, you still have to do it by hand (in a terminal).
Macfusion is a "frontend" for this so hides all the techinical stuff away from you. Once you've downloaded macfusion, copy it to your application folder and run it.
Once it's running, you'll see a new icon on your menu bar and you'll be able to mount your drive in r/w mode.
Am pulling my hair out here....when i click on the icon and bring up the ftp or ssh filing system it asks for stuff i dont know.... gotta be a easier way :(
Sorry, you'll also need this.
http://macntfs-3g.blogspot.com/
this is the user mode driver for macfuse to read ntfs drives.
Actually, once you've installed that you can run the enable script that is included in the install dmg and that will use this driver everytime you plug in an NTFS drive.
It will appear exactly as before, except you'll be able to write to it.
No need for macfusion.
i done it :).... all i did was run the disk utility and formatted it MS Dos FAT...now it works both pc and mac :) YEEAAAHHHHH
Yeah, well that will work. I just assumed you already had data on it, otherwise I'd have just told you to have done that!
Yeah i notice this now.... the above does work too... its the hardcore no prisoners approach lol
very good snoop.....resident mac Dr :)
