Harness Eye Bolts
Car  M135i and the shed
Does anyone know what size eye bolts i need to put harnesses in my R26? I'm intending on using the OEM rear seat belt mounts and wondered what size thread/pitch and length to use?
Any help would be great.
Measured them up. Sir Dave was right, they're an M10.
Anyone know where i can get an M10 eye bolt with a threaded length of about 30mm. I've found 23mm long one's but want them to be as close as possible in length to the standard fixing bolts as possible.
Cheers. :)
Cheers. :)
Has anyone found any longer shank m10 bolts?
JJC are well priced for those.
If you go for a 5/6 point harness, pop a hole through the floor and use a spreader plate underneath.
