has anyone ever changd sump gasket on rt
  172 cup,s2 rs turbo
easy enough but you might have to lift the engine up slightly to be able to get the sump past the subframe. Have a look at the headgasket area as that is a commen point for oil leaks on the old energy engines.
i had oil drippin away and looked around the rocker cover and it was pissin out there so check
rocker cover
oil filter
sump plug
all around the sump if u can
but there all pretty simple to do jus the sump itself is as JAY said a bit fiddly and ull av to drain all the oil out which u might as well change the filter while ur there meanin chaning the plug as well! lol
