Have I Solved My Problem ?
MarcB
  Vw Golf
Well last week i posted up a topic regarding poor starting / turn over of the trophy.
Its now happened atleast a dozen times so after changing the car battery, the battery's in the key fobs i was left with the TDC sensor.
http://www.cliosport.net/forum/showthread.php?699740-Needing-Advice-Help-ASAP
Today while the rain stayed away i decided to have a look at teh TDC sensor and give it a clean to see if that would help and i must say that the car starts super now and i'm not having the problems in the topic above.
MarcB
  Vw Golf
Im guessing im better off buying a new sensor & new loom to replace this current one?
  Clio Williams
You have already cleaned its end, just clean its connector aswell, that's all. It will work fine. If later it won't start, buy a new battery.
The_Pirate
  Golf R
If its not doing what it was doing before after you clean it up then i really wouldn't bother changing it!
MarcB
  Vw Golf
I have a brand new never fitted TDC sensor and loom, genuine Renault, for sale PM me
Tried PMing you regarding the part but your inbox is full.
Went and looked the kit up and got part numbers and prices.
  172/1.2/E30
It's a hall sensor so will wear out/fail. I'd replace it with a new one IMO
No, it isn't. It's a regular inductive sensor (gives a sine-like signal). A hall-sensor has 3 connecting wires (+,-, signal) and gives a square-wave output.
