Hi All
I have done a bit of a search regarding immobiliser problems on here and it seems the general consensus is that it is the reciever by the ignition barrel is the problem?
Anyway, i have a Clio 1.2 16v 52 and i have an issue with the hazard lights / immobiliser.
On tuesday night, i was driving home in traffic and indicated to pull into the next lane, someone flashed me in, and i put the hazard lights on to say thank you, then this is the start of the problem, the hazard lights wouldn't turn off no matter how hard i was pressing the button. In the end, i had to press and hold the hazard button to stop it from flashing. I eventually picked up some speed and i managed to turn it off.
The following morning, i drove to work, had no issues, locked the car and walked to work. When i came back to the car after work, i found that the hazard lights were flashing and must have been doing so for quite a while, as it had run the battery quite flat that i couldn't unlock it with the central locking, so had to manual open the door. Went to try and start the car and there wasn't enough juice to do so. Quick call to the AA and they come and put the jump leads and try to start it, nope, the immobiliser wont turn off and the hazard lights are still blinking away. Tried various things and nothing worked, so got towed home.
I fitted a new battery since the other one was dead, but now when i connect the battery up the hazard lights just keeps blinking and i still cant turn it off. If i try to start the cat the immobiliser light just stays on constantly, no blinking, just a constant light.
So does anyone have any ideas? Apart from towing it to Renault and letting them rape me for the sum of a few hundred quid? I have tried both keys, clicking it to POS several times, unlocking and locking the central locking. I'm at a complete loss here
