hazzard problems..... again.
Car  52 1.2 Clio Extreme
hey guys,
so, my hazzard lights just flash whenever they fancy (driving or parked) and i was told on here that it wpuld be the uch thats knackered. i took out the uch and sent it off to bba reman (who i was told is a decent company to go to) and they inspected it etc and told me they couldnt find anything wrong with it. 3 months or so went by without a issue, untill this weekend when it all started again. would any of you guys know if there is any other problem that would be causing this? i discovered yesterday that the pipe between the air box and intake is missing, and wondering if that could be a problem, or wether it is just the relay or the hazzard button. im stumped because im only on apprentice wage and cant afford to go to renault untill i desperately, desperately need to....
cheers for any help you all can give me.
loose/bad relay on the UCH? They're under the passenger footwell and can apaprently be easily knocked out by mates with big feet/anything that gets stuffed to the stop of the footwell, have a look to see if any are loose/corroded?
got same problem with mine at the min so will give this a try tomorrow great stuff :D
