Head gasket set price?
cheers Fred I'll have a look for them.
Any idea if I should get the head skimmed? If the head gasket has gone I will get it done, but if not is there any point?
check it?
what makes you thing you need a new HG?
No idea what i will need for sure until the head is off.
I am guessing i damaged the exhaust valves due to overheating/overboosting so may have damaged over stuff too.
i would say it is worth getting the head skimmed seen a few pugs with same problem after 8 months
For piece of mind I always get heads skimmed. £40 for skim and presure test it just makes sense.
Saying that I haven't touched a head gasket since doing one on a k series engine twice in 6months.
those manifold gaskets look a bit poop (having uses similar before ;) ). Headgasket is probably fine. If you can't afford genuine, I'd suggest Victor-Reinz gaskets as VERY high quality
