Headlight adjusters - testing
Car  BMW M135i; Clio 172
I want to test these are working before I refit the headlights, anyone know which connections are which so I don't burn them out?
Many thanks :up:.
You can easily pop them out, even with the headlights in situ.
Or just connect them up and get people to sit on the boot edge to lower it.
Thanks for the reply!
I meant how do I check the motors are working before I reassemble? They are already out of the headlights so I wanted to connect them up to 12v to see if they are working before reinstalling.
The headlight levelling doesn't work for some reason, nothing is broken in the lights, so I'm starting with these motors. Then I'll look at the mechanism at the rear. Should check there's a fuse there too :tonguewink:.
