Headlight Adjustment
Car  RenaultSport cup172 TT309
My Drivers side Headlight is a bit pointing a bit higher than the n/s. Both motors work fine, the lights move together and the same amount. Is it possible to adjust the position of the lamp manually ? If so how ? (172 CUP so not xenon)
Ste
:S
If you look round the back of the light unit there are white plastic allen bolt things. Turn these with an Allen key and the beam will move.
What he said.
Park it facing a wall with the lights on before you adjust them, then you can keep them level etc.
Do you mean the ones in the corner that are hard to get at especially on the o/s. Cause thats what i thought,and tried, and nothing seamed to move. Or is it the one on the back of the light unit ? (think i saw it)
Once i drag me arse outa bed will go n check it out !!!!
