headlight correction - couple of questions
  M135i
Im in the middle of doing the headlight correction (following the guide in the guide section) how long should i be sanding it down for roughly and how long did you spend buffering it up with the buffer ? Ive buffered it but theres still quite abit of that rough look to it.
Im doing it off the car as ive only just bought then and due to the wether havent had chance to fit them, so might come up abit better if on the car as more pressure could be applied.
Gaz_
  Extreme mode
I did mine at the weekend. I started with 800 grit wet/dry, then moved to 1200 then 1500. Then i attacked it with some power gloss by PC, then Intensive Polish. Come up well tbh. Will still source a brand new set come spring i think. I have a feeling they will soon fade back , its the protective UV layer thats actually damaged.
