Headlight Fuse
  Clio Dynamique 1.5 DCi
Hi there,
I've just had my car at the garage getting a starting problem resolved, which turned out to be an injection problem. Since i've got the car back though my off side headlight (mainbeam) no longer works :S I've checked the fuses inside the passenger side door and they are fine and i've checked the bulb aswell, which is also fine.
Is there any fuses under the bonnet which are for the headlights and if so which one?! Or if not is there any other things i should check?!
Thanks for you help,
Kev :D
Swapped the bulbs round this morning and that solved the problem, looked totally fine though with no sign of it blowing or anything, so not sure what has happened to it :S
Least i've got both lights back now tho :D
