Headlight sensor?
  RENAULTSPORT 182
my headlights have been turning on automatically when darkness approaches since I had my 182, no problem.
Al of a sudden this has stopped and I need to turn manually, no hale, just bugging me.
is there a sensor gone? Where is it, if there is one?
Any help wold be appreciated
  Renault Clio 172
You sure you just havent turned the automatic headlights off?
When the car is off, and the keys are out of the ignition, twist the headlight switch to the sidelight position twice. You should hear two beeps. This means its on.
Do it again, and you will hear one beep, indicating that they are off.
Hope this helps.
Dan
  Clio RN & Honda blade
Hi mate,
Same thing happened to mine, so scrolled through all the posts to see if anyone had the same problem and i found this one...
Problem solved now, so thanks for your knowledge:)
