Blk/Gold 182 FF
MOT failed on these not working.... Now im not sure if its the Jets at fault or the pump! neither jet fires but when i engage the washers, I can here the first Pump (windscreen) then a second later i hear the second pump kicking in..goes like - WERRRR werrrr then stops. Is that normal?
so how can i test if the pump is giving water out? if it is then i know its the washer jets to change..
