Headlights - Can I lower them without dashlights dimming
Car  FF182 Brembo Max, BMC CDA
Hi,
I want to lower my headlights using the little wheel adjuster on the right hand side but when i do the dashlighs and interior lights dim i dont want them to dim!
thanks,
Ollie
your full fat has xenons, which are self leveling. the wheel you are turning is actually the dash dimmer .
Yes, so you expect the dash dimmer switch to adjust the headlights?
Do you expect the heat controls to change gear?
ok ok, i never knew they were self leveling! i have never tried using the wheel before just thought i would have a play. sorry for being dumb
