Hear selector issues
Conor L
  Renault Clio Mk2
Just been out to my Mk2 and I'm unable to engage reverse gear, the collar lifts however the gear stick wont move to left to select. Another thing is when trying to select forward gears it is very vague and theres a horrible noise like the selector rod is hitting a heat shield or exhaust on brief inspection it does look like the rod from the stick to the gearbox has dropped. Any suggestions as to what the problem could be? Hoping not to be the gearbox
Conor L
  Renault Clio Mk2
Had a look under the car before work everything seemed ok took it to the garage where I used to work turned out to be the whole gear stick assembly. Searching the internet for a new 1
