does anyone no how you take the washer bottle out on a clio sport mk2. every time i put any water in it, its cuming out some where in the bottle so need it out to fix it!!!
I had the same problem. Resealed the pump onto the bottle and it was sorted... Also remove the fuse for you headlight washers if you haven't already, will stop the thing leaking out all the fluid without having to remove the bu,ber and change the nozzles/fit a non-return valve.
