When I switch my ignition on (engine not started) im getting a high pitch whine from the engine bay, also my speedo is locked on milometer can not change it. car starts fine, its only just happened.
motorised throttle body.poss a fault with the potetiometer tracks causing the motorised throttle to be vibrating in between the two set computer read potentiometer readings.the potentiometers(1 in the throttle pedal and one in the motiorised throttle body)have two tracks.if these go slightly out of line due to a fault with one of the tracks it might be enough to confuse the computer and cause the vibration due to it not quite being sure of throttle position(either pedal or throttle body) but not enough out of allignment for it to register a potentiometer fault.
the trip computer being stuck sounds like a faulty instrument panel.
i would go to your local dealer as both these will be under warranty.
