Symptoms:
Driving 'normally' the car is fine, not one issue.
As soon as you put your foot down to accelerate the whole car shakes, it feels the wheel on the nearside front is badly unbalanced, however the car has been checked and the wheels are all balanced fine.
Now the vibration is only there when the car is under load, if you put the car up on a ramp with the wheels off the floor you can accelerate up to 90mph+ without a single wobble! So the issue seems to be torque related.
So far the car has had Replaced / Checked :
Engine Mounts - All Ok (Vibra Technics less than 6 months old)
Engine Mount bolts - All Ok (Not snapped)
Both Drive Shafts - All Ok (Both replaced)
Wheel Balance - All Ok
Brake Rotas - All Ok
Clutch - New
Fly Wheel - Visually all ok and all Dowls Present
Have any of you Super Technical bunch ever come across this issue before? If so do you have any further suggestions?
I'm at the stage now where I just want to chuck a match in the car with a gallon of unleaded
Clutch - New
