Help!!! Broken xenon
  Renaultsport Clio 182
Had a pheasent fly out infront of me this morning and it hit right on the Driver side headlight. No damage to the outside of it just pushed the black grill in a bit which has moved back in to place but the light was now pointing towards the ground (i thought it wast working until i stopped and looked). Got it in the garage today anyway as they are doing the ball joints and they got the bumper off to sort out the grill and align the light but its fine and in the right place. Apparently its broke inside the light, the bracket which holds the xenon. Is this likely, and can it be fixed as a new light is £188???
Phil
the light itself, bulb is working fine but its pointing at the ground. so i assume its kncoked the light off its fitting inside??
  Clio 172
Dont know if they are interchangeable but i have a spare passenger casing (minus ballast bulbs etc) but it might have the bit you need :s would have to go rummage in the loft!
Drop me a PM if your still looking
Tom
