Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
Could be that your lock has got full of crud, or the relay has packed in.
I'm I right in saying that it's just your drivers side door if so look at your wiring and connections
Did my two back doors in just over an hour take the trim off you will need torx bits and spray wd40 or equivilent on the moving parts so where the bars go into the look and the pull lock move it uo and down a few times and when it works properly lock and unlock it a couple of times and put the cover back on and it should be ace. Check the connections as well while you are there.
i've investigated more and I'm pretty sure its the wiring/motor, there is no noise coming from it at all and I kind of (for a few seconds) got it working earlier.
I've tried to fix it myself with no luck so im taking to my mates garage tomorrow and hopefully they can sort it.
