Hello,
Right my car is having a intermittent problem that when sometimes I pull up too a stop the car will cut out on its own and the squiggly orange electrical fault light comes on, can wont start but turns over but if I give it some gas it will eventually start.
Also my idle isn't normal either, it used too idle at around 800 but now it wont go lower than 1100 and wont stick at that either it seems too bounce from 1100 too 2000 rpm. Sometimes it will idle at 3500 at traffic lights too.
Last thing is when I let of the gas and let the car roll to a stop in gear it will sit at 1200rpm and drive itself.
So far too sort the problem out I have checked all the connections I can see and all looked fine and in good condition, also took the throttle body off and gave it a good clean but non of this has fixed it.
Im thinking it could be the actually throttle body is at fault and needs a replacement.
Anyone got and idea's or similar problems them selves?
thanks in advance!
Josh.
thanks in advance!
Josh.
