Help Fitting Components
Car  1.2 expression+
Hi I'm new and as the title suggests i need help in the fitting of my components speakers.
I've got the dash off and fitted the woofer but can't find where the wire splits to go to the tweeter, so i can fit my tweeter and crossover.:S
Any help is appreciated thanks.
you should take the wire from you headunit into your crossover, the wire should be split from there, one to the woofer and one to the tweeter.
am i right in saying you want the woofer in the door pod and the tweeter under the dash in the oe spaces?
The speaker will be in the oe spaces.
So your saying that the split is at tweeter, but i can't see it??
You need to take the wires from your headunit and connect them to the "input" terminals on the crossovers.
Then run a set of wires from the crossover to the woofer, and a set from the crossover to the tweeter.
