I've just been to the scrappys to pick up a new instrument cluster from a Mk1 1.4 to fit into my Mk1 1.2.
Once it was all fitted I started the engine and everything worked apart from the tachometer. Now the reason I bought the clocks was for the tacho as mine doesnt have one.
The thing is it has the loom, so I though once connected it should work, alas, it doesnt. I know there is nothing wrong with the clocks, so am I missing something?
Is there a fuse somewhere that needs to be plugged in.
Any help would be great,
Thank you
Gaz
Thank you
Gaz
