Help me!!!
LiquidRich
  LY R27
Got a small problem with our 182. I removed the upper part of the intake manifold today to try and find out why theres oil on the rocker cover. I put it all back together, and when I fired it up the revs went sky high so I turned it straight off. I'm a little confused as I did exactly the same thing as when I changed the plugs last year.
Please help me :(
thanks peeps
  Megane dci 130
You will most likely have an air leak somewhere. Remove it and check all the rubber seals.
