HELP ME !!!
  Skoda Fabia vRS
right, im trying to install my components, ive now realised the only place im gonna get the tweeter is in the original location, so thats where its going
now to do this is quite easy fitment wise, its just the wiring thats a pain in the arse
what i need to do is, find the wires for the speakers which go into the doors and cut them and attach them to the mid/woofer bit on the crossover, but i cant find the pissing wires inside the car, i follow them to the connector block on the door, and then once they come inside all the wires seem to have changed colour, anyone know which wires INSIDE the car going to the door connector block are the + and - for the door speaker
if there is a Renault crossover anywhere i obviously want to by-pass that
I think there is a rwnault crossover somehwhere as you have two wires, whihc ive been told, one is for tweeter and other for woofer.
To tell which cable is which use a continuety tester
  Skoda Fabia vRS
i then had the idea of drilling through the blocks on the door wire connector block to put fresh wire through, which worked great on one side of the block, however i cant get to the bit thats attached to the car without taking the door off, and i dont have the right tools to do that
someone help me im losing daylight fast !!!
  Skoda Fabia vRS
well the fella over the road popped over to have a look at what i was doin and give me a few tools which helped matters a lot !
ive now managed to route through the doors 1.5mm proper speaker cable, its NOT an easy job
it took me 7 hours and 45 minutes to fit my speakers !!!
