HELP NEEDED ASAP
Car  Clio Sport 172
Hi guys I would appreciate any help or advice you may have. How do I input an immobiliser disarm code on a 2002 clio sport??? My immobiliser light will not go out no matter what I try!!! :mad: Many Thanks
you can't (well not without CLIP)
leave the key in the ignition for about 15min (lights on dash) that sometimes gets them talking, tried the spare?
No mate I had no spare when I bought the car. I've tried every solution on every forum with no luck. What was that CLIP you mentioned???
after disconnecting the battery to remove the dash, i had same problem .key button wouldnt disable alarm imobilser .i put key in ignition turned it to start and pressd the button on the key a couple of times.wether pressing the button matters not sure but was relieved that it worked
Cheers for the advise pal but I already attempted that and failed. I also tried to leave the key on ignition point 1,2,3 and 4 whilst disconnecting and reconnecting the battery but still not solved the problem. I've already had five parking tickets this week, any other solutions??? I have an immobiliser disarm code but from what I've heard you cant enter it through the console on the cliosport or can you???
