Hi guys, initially i thought i had a dodgey injector as when disconnecting the far right hand one, there was no change in engine noise like when the same was done to the other 3.
Then after swapping the right hand injector with one of the other 3, and the once again checking them all via disconnecting them all one at once, it is still the right injector which causes no change in engine note.
The only thing i can think is that there is a dodgey connection sumwhere on the right injector.
I have checked the spark plugs, HT leads and i am assuming there is no problem with the coil pack.
Please if you have any ideas then throw them this way as im stuck. Car is running rough as, so trying to avoid using it.
Thanks in advance.
Thanks in advance.
