LawrenceR
Morning all,
So after a bit of advice, or more likely confirmation of what I suspect....
Clio 172 Cup, sounds like it's running on 3 cylinders, it wanted to stall and really struggled between 2-3000 rpm, then would pick up and go.
I had the injectors cleaned on one of the group buy threads, I put new o rings in when refitting, I've changed the plugs for the correct ones and fitted OEM new coil pack and leads....still sounds the same, however it is a little more driveable than when I last drove it. It seems to go through the revs OK, but still sounds like it's running on 3 and it is really down on power. it drives and it has some get up and go, but it's not as it should be....
So, do I next try the LAMDA sensors, will that make that much difference or do I run a compression test and confirm what I suspect?
Engine is stock, a phase 1 filter, stock exhaust...
Any thoughts?!
Many thanks from a pissed off, sad Cup owner, I've been looking forward to going for a drive in this for a while!!
Any thoughts?!
