Help needed, temperature gauge showing half way when cold
Fodda172
  Clio 172 sport
Hi all need your help, my temperature gauge is reading half way when I turn the ignition on & the engine is cold.
I’ve replaced the temperature sensor with a gen Renault 1 & still the same, I’ve tried 3 different set of dials still the same, though it mite be an earth fault so I’ve spliced into the loom & added a permanent earth to the gearbox but still the same. I’m running out of ideas! 🤣 anyone had this problem?
