HELP PLEASE!!! - Passenger window and central locking fault...
Car  Clio 1.4 RT V-reg
[h=2]Hi there,
I have 2 problems with my Clio V-reg Mk2 Ph1.
[/h]
1. The passenger window will go down when pressing the button on the passenger side but wont go back up - So i have to use the drivers buttons to put it back up. Anyone know how to fix this?
2. When using central locking, everything will lock and unlock but the driver door wont lock or unlock, so i have to use the key to do so. When i press the central locking u can see it shake a bit which means it wants to do it but something is stoping it, anyone know what is causing this and how to fix it?
Any help will do​
For problem 2 take the door card off spray some wd40 on locking unit & solenoid + check connections, put it all back together lock and unlock door with key to loosen it up a little then have a go with the key fob...
If still no joy change the solenoid mate
