-----> Help plz <-----
Car  clio 182 04
anybody know were i can get a clio 182 manual? the one that tells you everything about the car and fuses etc...:(?
Ok, both sidelight fuses are red 10A fuses. They are on their own in the bank to the right hand side as you look at it,
if its like my mk2 ph1 then if u open the passenger door and look at the end of the dash theres a removable panel
could be wrong tho
just checked the fuses there not blown but my drivers side sidelight is still out any one know how i can fix it thanx....?
Then it's not the fuse, as they're both on the same one. It must be a local problem to that headlight. Have you checked the contacts within the lamp holder? Also try swapping lamps from drivers to passengers and back.
