Help!!! Removing Discs!!
Car  RS Clio 200
does anyone know how to get the discs off a 172?
i undone the star screw, but it wont budge... do i have to un do that bolt in the middle?
they should come off but may need help.where the bracket is that holds on the brake caliper is, located slightly behind the disc screw the bolts back through it and . In a way round about kind of way screw they disc off by forcing it away from the hub.
Hitting it with a hammer probably wont work either.
I changed my brakes a week ago mate took me a while to figure it out they just almost rust on.
Hope that made sense .:dapprove:
If you have a copper hammer try using that to hit the disc, rotating it to hit it in different places and it should slowly ease it's way off.
Hitting it didn't work for me , but may work for you .
Follow Mikes guidance though he's the don. Hope the business is going well Mike.;)
Heard really good things about you on here , keep up the good work mate
Hub Nut ???????? Only on the rear brakes fella , never un done the hub nut on mine the disc bell or centre fits over the hub and the disc is fixed in place with the screws and wheel bolts
You certainly dont have to undo the hub nut.
The discs are just stuck on, hit the old discs like a man not a mouse ;)
no need to touch the front hub nut on any clio to get the disc off
get a big f**king hammer and beat this s**t out of it, it WILL come off
twatted mine with a hammer and made loads of dints, then realised i had the wrong disks to go back on :quiet: the company that made my grooved disks sent 238mm instead of 258mm the tits
JUDO CHOP!
i cant believe there is a thread about getting a disc off a hub!
That'll teach you lot for putting them on dry!
