HELP?! Throttle Cable Problem on a MK2 PH1 Clio.
Car  Clio Mk2 Ph1 1.4
Code:
Hi all, Need help with my MK2 PH1 clio,
Recently I've noticed that the throttle feels very different to what it did previously, almost like the cable is rubbing on the firewall?
I have also noticed that the RPM's seem to fluxuate between 1K and 3K, almost like the tickover speed is set too high.. But then when I pull the throttle upwards with my foot under the peddle, it goes back to the 1K that it should be.
It is really starting to bug me now, as I'm cautious that it could do it whilst driving and make me accelerate.
Anyone have any idea what it could be? Like is it a typical fault with PH2's?
Please excuse any spelling or grammar mistakes as I'm on my phone and its a bit of a sod to type everything with a keyboard so small.
Thanks in advance, any help would be much appreciated.
Jord.
It needs a new throttle cable. Yes, it is a common problem and you will have to buy a genuine Renault cable from the dealers. Should be £25 or so. Fitting it isn't difficult but can be a bit fiddly. Don't buy a non-geniune cable, you have been warned!Cheers
