HELP! URGENT!
I've just had to pull over as there was steam (I don't think it was smoke) coming from my bonnet. I opened the bonnet and the coolant tank is bubbling.
Before this I had been sitting with it idling for about 30 minutes.
Is that the head gasket gone? Is it dead?
Please help!
The fan has not cut in to cool the water, and if stationary, there is no airflow. Was there no warning from the temperature gauge?. Let it cool, before adding any water, then start. Check the oil level, and if car starts, keep checking both, you might be lucky.
Not necessarily, how far had you driven before having to pull over?
Could you hear the rad fan switching o and off while it was idling?
Does the coolant in the header thank have oil in it, or just look a really bad colour?
Only drove for about 5 seconds then pulled over. ThE liquid is brown and on the minimum line. I didn't notice the fan or any warning.
I would agree, water on its own is a bad idea, but he might not have access to anti freeze where he is. Water will get him home.
Where was the steam coming from, belt side ? Water pump could have gone and the lack of pressure caused the coolant to boil ?
