Help will these spacers fit my car ?
That is 10mm per Axle mate - so those ones in that link will give you 5mm at each wheel
They will fit :)
wouldnt make any difference though would it warren as there all 4x100?
not sure possibly cant imagen renault changing the bore.
Another thing aswell warren alot of stuff for mine is classed as 2004 even tho its a 2005 car
yea but yet renault made the Ph3 in 2005 with the new engine and front bumper just confuses things doesnt it lol
http://www.fk-automotive.de/websale7/Wheel-Spacers-%26-Adapters.htm?Ctx={ver/7/ver}{st/3ea/st}{cmd/0/cmd}{m/websale/m}{s/fk-automotive/s}{l/English/l}{mi/2-2823/mi}{p1/913814f5219b271bd91f5c70a6479420/p1}{md5/2db22f9b4ca25c314d594d25c6d2f7c7/md5}
They are indeed!
They aren't hubcentric though which is a pretty major factor IMO.
You should be fine with 10 rear as I now have the 13's on the rear. ;)#
Quick search seems to show that you can't get 10mm a side in hubcentric, so I can't comment on that!
Yeah 15mm a side, depends how low your car is, mine is on Sportlines and I have no problems! (about 30-40mm)
Any lower you may have problems..
They're almost double the price of the FK 15mm a side ones though! (hubcentric)
im going to going about 80mm at the front nd 90mm on the rear what size would i need ?
How wide are your tires?
195?
at the rear I would suggest only 5mm a side then!
BUT
You would be best waiting till the car is lowered and then measure the gap between the tyre and arch and get some based on that! :)
i need the spacers to fit my coilovers as they rub on the wheels with out any on lol
Well if your tyres are 195 5mm on the rear and maybe 5-10 on the front (per side)
You should maybe drop Android a PM as he had this problem, so he can tell you what he has on his. ;)
Android is that his form name then ? ill drop him a pm. i might be getting 16inch alloys soon lol
