HELP!!! Windscreen Washers
Car  Clio Sport 172 Mk2 Ph2
hiya guys, i was driving home the other day sprayed my windscreen, it worked normally to start with and now only the left hand jet of each nozzle works, which i s well annoying as the spray now doesnt cover my windscreen. :mad::mad::mad:
Not to mention my zenon headlight washers have never worked. i think its the pump thought as its done it since i brought it.
im thinking possible blockage??? if so how the bleeding hell do i fix it!!!
Sounds like it all need flushing out.Pull the pipes off put washers on and keep topping up bottle with fresh water,because after a few years the bottle gets all gunky at the bottom.
Once you have discon the pipes you will need to either blow the jets out with an airline or a can of compressed air (Maplins) or use the pin method.
