Audi TT 3.2 V6
Hi,
Started on my amp install this afternoon. Ive decided id like to put a wooden panel at the side of the boot and have the amp mounted on the back of it so that it is hidden.
So far ive cut out a panel to the size required -
It does fit better than it looks, when the panel is pushed back as far as it can go its a very snug fit.
The problem i have is that my amp (JBL 75.4) is too deep to have the wood pushed back as far as it can go and mounted on the back so needs to be spaced, i have cut a bit of card a little depper than my jbl to show roughly how big a spacing i need.
Does anyone have any suggestions on how i could space the panel securely in the position i need?
As you can see in the photo below i would also need to fill the gaps left around the edge so that the amp is out of sight. Anyone have any suggestions how i could do this as well?
Thanks alot,
Russ
Thanks alot,
Russ
