Help with my lights....
Car  Focus RS
Not sure if im sticking this in the right section but I need some help please guys.
Just had my FF 172 lowered 40mm and now I can see at night. Since Ive lowered it the headlights seem to only shine about 4ft in front of the car. I thought that Xenons were supposed to auto adjust? Is there any way that I can adjust these myself or is it a Renault job?
Cheers chaps
Behind the Xenons in the engine bay, theres a little white sort of screw that will have a head like an Alan Key. This should be able to allow you to adjust the beam up or down.
Chris
The proper way to do it is to get Renault to adjust it using there computer but the easy way is to look under the rear beam of the car you'll see a screwable sensor yyou adjust this and it makes the lights go up and down. Whats happened is the back of your cars lower the sensor things the backs loaded up so lowers the lights you need to adjsut the sensor is its normal position is the position it is now.
