Help with my lil install
posted up about 2 months ago but get my components tomorrow and gotta fit em up in 1 day!
Scenario: 3 way components, tweeters, 6" mids & 6x9s
Position: tweeters in the front dash speaker compartment
mids in the doors
6x9s in the rear door cards
right need help with where to stick the crossover (not goin on show!!!), heard its a b**ch to rewire the door cables so im thinkin behind the glovebox
how to attach the 6x9s to something solid as i believe its jus a huge hole behind the material and plastic bak
how easy is it to cut away the metal etc to fit the components
http://forum.cliosport.net/display_topic_threads.asp?ForumID=3&TopicID=64211&SearchPagePosition=1&search=riplash&searchMode=allwords&searchIn=Author&forum=3&searchSort=dateDESC&ReturnPage=Searchhttp://forum.cliosport.net/display_topic_threads.asp?ForumID=3&TopicID=64211&SearchPagePosition=1&search=riplash&searchMode=allwords&searchIn=Author&forum=3&searchSort=dateDESC&ReturnPage=Search
Cheers for the help
As for the crossovers, im planningt o ,mount mine in the boot wiht the amps.
If you have a 3 door you could replace the rear pannel wiht 18mm MDF and mound em in the, if you round the edges off and carpet it it should look quite good.
Thanx to RB_172 for lendin me his alpine amp this should sound quite good but we got 24hrs inwhich to install the whole setup
gettin the speakers later today so gonna start making some brackets for the tweeters and then hunt down my jigsaw ready
will probably need to make a new card for the 6by9s, as theres no room behind the card, above the arm rest, as the magnet would hit the metal, unless u remove the arm rest, but may look cack.
Do what lunner said with the 18mm MDF.
Metal shouldnt be too hard to cut to get the components behind the doors cards.
A mini circular saw should do the trick.
  Clio 172 Ph2
oooh, it just so happens I got one of those little dremel professional thingys the other day when I was in B&Q. That should do the job! Ill bring it with me Essex_Lad ;)
ill start on the rear door cards on thursday night coz i gotta cutr those out and carpet them so would rather get that out wit way!
Also sortin out some brackets for the tweeters so we should be less rushed friday!
