Help with part numbers
Car  Tungy
Right I'm not being lazy. Just not 100% sure. On my MOT failure form one of the thigns said:
Offside front trackrod end ball joint has excessive play.
I've narrowed it down to 2 parts on GSF.
R43660TIE ROD END-RH CLIO (MALE) 12.50 Add R43660ATIE ROD END-RH CLIO FEMALE 12.50
Will it be one of those I need? If not then what?
Also the other bit I need is the nearside cv joint gaiter, hubside. I'm guessing it is this, althought it doesn't mention 16v
R45024 CV BOOT KIT-OUTER CLIO 1.1/1.4/1.8 THERMOPLASTIC OUTER 6.90 Add
If someone could assure me that would be a lot of help. Thanks.
You need to check I think its most likly the female one you need.
As for the gaiter I'd personaly get a new shaft there a bugger to fit if your DIYing it either get one of the universal fixers or better still get a new shaft its so much easier.
